shift6mq bricked / stuck in boot fastboot mode screen.
Jan Wagemakers
13 April 2023
7
Hello,
My shift6mq is stuck in the boot fastboot mode screen. Trying to get to recovery or fastbootd mode doesn't work, whatever I try. I'm stuck in the screen below. More info in what I've tried so far at https://www.janwagemakers.be/jekyll/postmarketos/sxmo/mutt/2025/08/04/broken_shift6mq.html . Any ideas what I can do to fix this problem?
Send in your smartphone. I think EDL is the only and correct way here after all you have tried. However, the problem here is that I am not (yet) aware of any published compatible firmware package. However, according to other forum participants, a new flash should not be that expensive. I think I remember €26, correct me if I'm wrong...
Could you please fastboot --set-active=a and try if it boots now?
Done. Still brings me back to this 'fastboot mode boot' screen.
(bootloader) current-slot:a
(bootloader) has-slot:boot:yes
(bootloader) slot-retry-count:b:7
(bootloader) slot-unbootable:b:no
(bootloader) slot-successful:b:no
(bootloader) slot-retry-count:a:7
(bootloader) slot-unbootable:a:no
(bootloader) slot-successful:a:no
The weird thing about this is also, that your fastboot version claims it is: version-bootloader:5.0.20221224, whereas after flashing ShiftOS 7 it should be 20250528.
So it seems that flashing does not really flash anything at all.
Without EDL/QFIL this seems to be a bit hard to work on but maybe what you could try is booting the recovery image directly and see if that boots up, via fastboot boot recovery.img and then install the system via OTA.
If that does not work, you could also boot into fastbootd from within that recovery (it will not reboot but start fastbootd, which is included in the recovery) and flash there again.
Otherwise if all fails, maybe trying to live boot into pmOS and manually flash partitions there via dd.
Reaktionen: Jan Wagemakers
This also fails.
$ fastboot boot recovery.img
Sending 'boot.img' (98304 KB)                      OKAY [  2.379s]
Booting                                            FAILED (remote: 'Failed to load/authenticate boot image: Device Error')
I really appreciate your help. Thanks!
Maybe it's time to think about plan B and just send in my shift6mq to fix it...
To complete the story. I've downloaded the iso from https://github.com/bkerler/edl to test edl. In EDL mode i've flashed manually the .img-files, but the problem persists.
So today I went to the post office and my shift6mq is on its way to SHIFT GmbH Support/Reparatur.
Reaktionen: @Lhotze
I've just payed 16€ to flash the software.
