I must say being an owner of the LG V20, having 2 chargers for batteries, how people can be so blind to the power of easy changing the battery and have full charge. You don't need to have any fast charge at all, you just need to be able to recharge a battery outside the phone, and with the LG20, it takes so little time to do as the cover flies off easily and the exchange it done very quickly.
Of cause it also helped me when the internal charger burned somewhat off in my mobile, although still charging it is very very slow. Something broke when I tried a foreign charger, it got really heated and sadly it damage my V20 phone in regards of charging. But not a big deal as I had the two battery chargers.
In any case, I would absolutely suggest Shiftphones to look on a Battery charger, this is something that is very very nice to have. Like we Exchanged sanity with exchangeable batteries with insanity closing it all up - with all different synthesis technologies of charging and issues with cables and getting the correct charger, a fully mess of nonsense - when the old way worked without issues.
Of cause the Devil always wanna waste our time, and he does a great job at that. It's near to impossible to get a mobile with the ability to change battery and of cause with to small battery life time with them as well.
If it had been possible, with my low resources I would have gotten another LG 20 - but ... Because of the Corona propaganda and nonsense - they could not send anything from Hong Kong. So I have now ordered a Shift Phone Although 5-6 times as expensive but if it can load me 4-5 years like the LG20 well then I'm happy.
But really, a charger like the LG V20 had, would be perfect !!! Although both of my chargers are now having trouble as well charing the batteries. Things are not made to last, it's utterly disgusting. But at least They had them - And They where as far as I recall not that expensive Either, although the quality which CLEARLY not something big either.
Looking forward to the Shift 6mq - I was looking at Librem 5 and Pinephone and the hype over the Librem 5 was high high high, and yet the product they came out with was clearly not finish for daily use. So looking for other options, Fairphone3 or the Shift 6mq - in the end I concluded I just better buy another LG V20 and go with that for another second time. But what did not possible, at least not in lockdown synthesis times.
So in any case I ordered the Shift 6mq, and hope for the best. It looks good, but the price was also 5-6 times the LG V20: P If it was not a money issue, I would surely go with the Shift mq6 and have no bother about thinking on what to do.
It's interesting how people using an LG V20 - hanging dearly unto it, have not had any other mobile to replace it with for what, 5 years? I would still give the LG V20 2-3 stars out of 10, but it absolutely is still the number 1 phone as far as I can see beside finally having a replacement in the Shift 6mq. But locking the LG V20 phone of cause takes a lot of stars off and other nutty things and issues. Screen ghosting and what is a thing and the camera glass was just to fragile, and the glue apparently not good enough either for it.
They did not even sell the LG V20 in Europe, here everybody is talking about the green agenda, and then those hypocrites then goes out buying phones where the battery cannot be exchanged. Overall the green agenda is used for Satan, if people just made things like good old German quality then people would not need to replace there things or buy new things all the time, and thereby you would lower the trash outcome. But that's not how the Devils world works! Overall there is a lot of nonsense that people follow - it is all in the end for collecting the world around the Roman Antichrist of the number 666.
Of cause any German should know that the Papacy is that Antichrist - but ... people tend to fall a sleep quickly. You had one of the loudest reformers on the subject!
Not sure if it is the forum or Google Chrome I'm using that is changing some of my text on the fly, I needed it to translate the German into English. But It Seems to mess up my text here and there, Which I then need to correct and fight the system.
Anyway, an outside charger, just a small flat one like the LG 20 would indeed be a nice thing to have - it should not be the most difficult to make I would think? And it really it is a huge winner and there are quiet a lot of people who quietly have some sanity left and uses search phones like the LG 20 Because of.
I guess it must be the google nonsense which thinks it should edit my text message on the fly ... In any case a mobile have to have 3 things before it is worth a look. SD memory, battery removal and Jack stick - and it being jail broken out of the box, or to say not criminally locked by the selling criminals, is also one of those really biggies.
So surely I would also like to see an outside Charger for the Shift 6mq for sure !!!
Or a 6400mAh battery with plastic soft cover, did Seems fitting for my LG V20, not to big like the 10.500mAH and protective of the camera and all ...
If there is any issues with my text, thank bullshit google for changing things on the fly. very annoying.
- Dearly regards
Darkijah
