crash system, HELP
Hakimouse
2 September 2020
31
Hello everybody,
My shiftphone just crashed after 1 month !!! I will loose all my data, help !? I've installed Shift L OS following the process in the forum.
anyone ?
Maybe you can give us a little bit more information about what you did before this happened and what happens exactly! It is possible that this happened out of the blue but maybe it is caused by something you did before.
I see you got your phone around the 9th of November. So did you start with the latest version (SHIFT6M.SOS.1.1.L.20201126) which also was released on the 9th November or did you upgrade at a later time? If yes maybe the upgrade is to blame!
Also from the image you have attached it seems that you are not stuck at this state but are ale to continue booting normally. Is this true or does the phone not even boot?
