USB headphones and volume
thor_n
18 Februar 2026
13
Ringing in USB headphones is very quiet. I can barely hear the ringing tone.
When the call is connected the volume is extremely loud. Loudness is at minimum and cannot be set lower but the sound is very loud and can be set only louder not quietter.
Is there a way to change this?
When using headphones to play music, the volume can be controlled normally.
This is a known issue and has been discussed here before. Shift is aware, but it is unknown when a fix will be available.
Please consider searching the forum before opening new threads. Chances are your questions have already been addressed elsewhere.
Yes, really.
Are the volume controls better when you enable/disable absolute volume under System > Developer options? You may first need to tap Build number seven times under About phone to unlock the Developer options.
Found this "Disable absolute volume" under Developer options. I was off.
Now I'm testing it with on. Will see if anything changes (it says bluetooth in description)
