[DEPRECATED] (SHIFT6mq) crDroid 9.20 Unofficial (Android 13)
Ene
21 Oktober 2020
207
Germany / Bavaria
crDroid 9.20 (Unofficial)​
General
I compiled crDroid for the Shift6mq!
Prerequisites
  • unlocked bootloader
  • TWRP recovery
Download
https://drive.google.com/file/d/10oPecsZfnCEe1-u6_cfXx8CGl-lPvCyW/view?usp=sharing
Install
Flash the ZIP using TWRP. Make sure to remove the lockscreen of the current ROM before, wipe everything in TWRP, reboot into TWRP and then flash
Update
Just flash the ZIP and wipe cache. Then restart into bootloader, flash TWRP again, boot into TWRP to flash additional ZIPs
Source
Building
To compile it yourself you just have to follow these simple steps (and need a beefy PC)
  1. install Ubuntu 22 LTS Desktop (optionally in a VM)
  2. change terminal preferences
  3. after setting everything up, execute the following commands in the terminal
    1. install programs
      sudo apt install bc bison build-essential ccache curl flex g++-multilib gcc-multilib git git-lfs gnupg gperf imagemagick lib32readline-dev lib32z1-dev libelf-dev liblz4-tool libsdl1.2-dev libssl-dev libxml2 libxml2-utils lzop pngcrush rsync schedtool squashfs-tools xsltproc zip zlib1g-dev lib32ncurses5-dev libncurses5 libncurses5-dev python-is-python3 -y
    2. install repo tool
      mkdir -p ~/bin
      curl https://storage.googleapis.com/git-repo-downloads/repo > ~/bin/repo
      chmod a+x ~/bin/repo
    3. configure git
      git config --global user.email "you@example.com"
      git config --global user.name "Your Name"
      git lfs install
      git config --global trailer.changeid.key "Change-Id"
    4. configure ccache
      rm ~/.cache/ccache
      mkdir -p ~/.cache/ccache/tmp
      echo export USE_CCACHE=1 >> ~/.bashrc
      echo export CCACHE_EXEC=/usr/bin/ccache >> ~/.bashrc
      echo export CPU_SSE42=false >> ~/.bashrc
      ccache -M 50G
    5. configure working directory (note that mine residents in the folder /media/builder/repo, change accordingly)
      mkdir -p /media/builder/repo/crdroid
      cd /media/builder/repo/crdroid
      repo init -u https://github.com/crdroidandroid/android.git -b 13.0 --git-lfs
      mkdir -p /media/builder/repo/crdroid/.repo/local_manifests
      cat <<EOF >>/media/builder/repo/crdroid/.repo/local_manifests/axolotl.xml
      <?xml version="1.0" encoding="UTF-8"?>
      <manifest>
        <project path="device/shift/axolotl" remote="github" name="LineageOS/android_device_shift_axolotl" revision="lineage-20" />
        <project path="kernel/shift/sdm845" remote="github" name="LineageOS/android_kernel_shift_sdm845" revision="lineage-20" />
        <project path="vendor/shift/axolotl" remote="github" name="TheMuppets/proprietary_vendor_shift_axolotl" revision="lineage-20" />
      </manifest>
      EOF
      repo sync
    6. optional - increase SWAP size (to 20GB) to prevent out of memory crashes
      sudo -s
      swapoff -a
      rm /swapfile
      fallocate -l 20G /swapfile
      chmod 600 /swapfile
      mkswap /swapfile
      swapon /swapfile
  4. build!
    source build/envsetup.sh
    brunch axolotl
This will take about an hour and about 350GB of Disk space (tested with 28 cores and 60GB RAM). The build process sometimes crashes because it runs of memory (exit code 137), just run the brunch command again. The flashable ZIP can be found in /out/target/product/axolotl
TWRP?
Gibt es inzwischen ein funktionierendes?
Gibt es schon Erfahrungen von dieser ROM?
Vielleicht auch Deutsche Quellen dazu, was diese nun besonders macht im Gegensatz zu den bereits bekannten und wie es mit den GApps aussieht, sofern man diese benötigen sollte.
War mir bis jetzt unbekannt. Sowie ich gelesen hab, basiert es aber auf LOS und hat schon die problematischen April Security Patches drin. Das Problem konnte also wie es scheint von LOS inzwischen gefixt werden.
TWRP?
TWRP ist vermutlich nicht unbedingt nötig. Die ROM ZIP kann auch extrahiert, die payload.bin extrahiert und die Partitionen einzeln via fastboot geflasht werden. Die ZIP kann man wahrscheinlich auch mit dem LOS Recovery flashen, allerdings wird bei dem vermutlich die Signatur als ungültig erachtet und das flashen abgebrochen. Beim Buildern von crDroid wird auch immer ein Recovery generiert, das aber zuerst flashen zu müssen um danach noch die ROM zu flashen fand ich unnötig, da ich ohnehin schon TWRP nutze.
crDroid ist die ROM mit den aktuell meisten Einstellungen (alles was früher mit GravityBox geändert werden konnte, PixelXpert aber nicht mehr bietet) und für mich essentiell um ein brauchbares Gerät zu haben (Material You ist eine absolute Katastrophe). Ich hatte bereits die crDroid GSI genutzt, welche allerdings einen nervigen Audio Bug hatte.
crDroid 9.15 hat Sicherheitspatches von März, crDroid 10.4 hat schon die von April, allerdings funktioniert damit der Fingerabdruck Sensor nicht richtig, alleine komme ich da aber leider auch nicht weiter.
Wäre dann auch eine Überlegung wert für mein SHIFTphone 8 (*auf Notizzettel pack*), natürlich nur, wenn sich jemand finden würde, es zu bauen.
was müsst ihr denn umstellen was es im Shift OS und AOSP nicht gibt derzeit?
Das zu bauen dauert auf meinem System so 20min, das wär nicht das Problem ^^
Leider ist die Hardware beim SHIFTphone 8 sehr bescheiden (kein Aux Port, keine Notification LED, viel zu runde Display Ecken...) weshalb ich nicht weiß ob ich es selbst nutzen werde.
QuickSettings anpassen, NavBar anpassen, Statusleiste anpassen ect. Das mache ich seit Cyanogenmod auf meinem 4X HD damals, kann stock AOSP nicht mehr richtig nutzen. Seit Material You ist die UI ohne tweaks echt absolut unbrauchbar.
Das wäre mir neu
Mir auch.
Das zu bauen dauert auf meinem System so 20min, das wär nicht das Problem.
Das ist ja super.
Das phone 8 hat imho die besseren Specks als das 6mq
U.a. (bzw. zusätzlich zu dem, was ene bereits schrieb):
  • Privacy-Optionen: Z.B. Einer App vorgeblich eine Berechtigung geben, ihr aber nur Dummydaten oder gar keine Daten liefern.
  • Startton und -viedeo des BS ändern oder abschalten.
...aber der Fingerprint-Bug ist bisher nicht behoben?
Das Problem hatte ich beim testen der crDroid 10 GSI und bei meinem eigenen crDroid build. Laut crDroid Entwicklern ist das kein allgemeines Problem, manche andere Geräte wie das Pixel 2 betrifft das aber auch. Der Android 14 LOS build hat das Problem nicht. Da das aktuelle TWRP die /data Partition nicht richtig sichern kann, kann ich leider nicht zwischen ROMs wechseln um zu überprüfen ob das in der Zwischenzeit gefixt wurde (ist aber unwahrscheinlich).
...irgendwo in den Weiten des www hatte ich zu Huawei gelesen, daß ein wipe cache Abhilfe bringen kann...
Vielleicht ist das einen Versuch wert... 🤔
Da es ja mit LOS21 funktioniert habe ich die Vermutung, dass es an diesen commits liegt:
https://review.lineageos.org/c/LineageOS/android_device_shift_axolotl/+/382746
https://review.lineageos.org/c/LineageOS/android_device_shift_axolotl/+/382745
Ich weiß nur leider nicht wo ich das beim crDroid builden am besten einbringen sollte.
Da kann ich leider nicht helfen ...bin ja nur "interessiertes greenhorn"... und blicke eher bewundernd in Eure Richtung...
Ich habe es mir mal drauf gemacht. Für Bastler und Spieler bestimmt eine feine Sache. Fingerabdruck funktioniert natürlich (da Anroid 13). Einstellungsmöglichkeiten ohne Ende. Ota´s funktionieren glaube ich nicht, da wenn ich den Updater bemühen will zu suchen, immer die Meldung kommt "keine Internetverbindung, versuche es später nochmal". Internet funzt aber. Kein App-Store vorinstalliert. Ob Seedvault Sicherung hier funktioniert, wollte ich nicht mehr testen, da dieses OS für mich nichts ist. Ich lass crDroid aber noch ein bisschen drauf, falls jemand etwas wissen will. Aber bitte nicht zu tief ins Android gehen, da ich mich in crDroid nicht auskenne und auch erst mal suchen muss, wo der eine oder andere Punkt zu finden ist.
OTAs funktionieren bei allen Unofficial crDroid nicht, um die ROM Official zu bekommen muss man aber ein paar Voraussetzungen erfüllen, was mir zu aufwändig war. GApps darf man lizenztechnisch ja nicht mitliefern und wer Alt-Stores nutzen will kann die ja einfach selbst installieren. Ich nutze Neo Backup, wüsste auch nicht warum andere Apps nicht funktionieren sollten.
@Ene , mal 2 blöde fragen! Kann man die Vibration stärker einstellen? Lassen sich die Klingeltöne lauter einstellen als bei den anderen Fremd OS-Systemen?
Man kann das Vibrationsmuster konfigurieren, aber selbst wenn man dort alles auf Maximum stellt wird die Vibration nicht stärker, der schwache Motor des Geräts ist da der limitierende Faktor.
Die Audioausgabe vom Shift 6mq ist prinzipiell viel zu leise (auch bei dieser ROM), konnte im Internet aber nicht herausfinden welche Konfigurationsdatei (vermutlich irgendwelche *mixer*paths*.xml Dateien) man vorm builden anpassen muss um das zu ändern.
Einerseits die ACDB Dateien mit QACT anpassen (ist aber ein proprietäres Tool von Qualcomm) oder bei den mixer paths die GAIN Werte anpassen.
Sie sind aber extra so limitiert wie sie sind, um die Lebensdauer der Hardware zu verlängern.
Als Beispiel wie andere Geräte die Gains erhöht haben:
- https://review.lineageos.org/c/Line..._onclite/+/393591/1/audio/mixer_paths_mtp.xml
- https://review.lineageos.org/c/Line...0lte/+/395379/1/configs/audio/mixer_paths.xml
- https://review.lineageos.org/c/Line...0lte/+/380496/1/configs/audio/mixer_paths.xml
Den Vibrator kannst du normal auch ein wenig stärker stellen, indem du die max mv bei den Haptics einstellst.
Hab aber gerade keine sichere Range im Kopf, also ist auf eigene Gefahr.
Beispiel von solchen Anpassungen:
- https://review.lineageos.org/c/Line...53/6/arch/arm/boot/dts/qcom/cheeseburger.dtsi
crDroid Version 9.20 hochgeladen.
Ich hab versucht die Lautsprecher Lautstärke und den Vibrationsmotor zu verstärken.
#!/bin/bash
cd ./crdroid
rm -rf ./out/*
repo sync --force-sync
sed -i 's/if (\!shiftEnabled ||/if (shiftEnabled \&\&/' ./frameworks/base/packages/SystemUI/src/com/android/systemui/statusbar/policy/BurnInProtectionController.kt
sed -i 's/"HPHL Volume" value="20"/"HPHL Volume" value="45"/' ./device/shift/axolotl/audio/mixer_paths_tavil.xml
sed -i 's/"HPHR Volume" value="20"/"HPHR Volume" value="45"/' ./device/shift/axolotl/audio/mixer_paths_tavil.xml
echo '&pmi8998_haptics {
qcom,vmax-mv = <1600>;
qcom,wave-play-rate-us = <4347>;
qcom,lra-auto-mode;
status = "okay";
' >> ./kernel/shift/sdm845/arch/arm64/boot/dts/qcom/axolotl.dts
brunch axolotl
Mein Shift 6mq war jetzt für 6 Wochen defekt und ich hab es jetzt erst testen können aber gefühlt ist der Lautsprecher jetzt lauter (wenn auch noch nicht laut genug) aber bei der Vibration merkt man nicht viel, ich denke der Motor ist einfach zu schwach.
Edit: Der Lautsprecher ist doch nicht lauter und ich hab ihn bisher auch noch nicht lauter bekommen, ich weiß echt nicht welche Werte ich jetzt tatsächlich anpassen muss.
