[SOLVED] Device no longer 'Play Protect certified' after update to LineageOS 22.1
BoredStudent
13 Januar 2023
6
Netherlands
I've been running my SHIFT6mq with LineageOS ever since I got it about 2 years ago without any issues. Yesterday I decided to update from LOS 21 to 22.1 (build 'lineage-22.1-20241231') and all seemed fine, until I noticed some apps won´t open. They instead display a screen telling me my device "isn't Play Protect certified" (screenshot attached) and it won't allow me to use the app. So far I've only noticed this issue in some Google apps like YouTube and GMail, but most importantly the Play Store as well... I did update MindTheGapps before rebooting to system when I updated LOS from recovery using ADB sideload.
At first I thought the issue was related to Magisk, so I've tried:
- Rehiding Magisk
- Reinstalling Magisk
- Using the 'Play Integrity Fix' Magisk module
The weirdest part of this is that, with the 'Play Integrity Fix' module installed, the 'Integrity Checker' app does show two green checks for 'Device integrity' and 'Basic integrity', but I still get this issue.
I've done a lot of searching online and couldn't find anyone else with the same issue that wasn't solved by this Integrity Fix module. So I'd like to know: is there anyone else on here with the same issue? If so, I'd like to hear what you have tried and if it had any results. I would prefer not to have to do a clean install of LineageOS, but I'll try that in the coming weekend if I haven't found a fix before then.
EDIT: The problem has been solved! See @getle's reply (#6) below for the fix. I personally had to wait about a day for things to start properly working again.
LineageOS is not "Play Certified". Never been. You can catch and spoof this (as described by you) if you hide root and use modules like "Play integrity fix" with the right fingerprint, "Tricky Store" with the right keybox and modules to hide LSposed and root.
But you will probably never be able to do this with LineageOS out of the box without root.
LineageOS is not certified by nature.
But I also have the feeling that Google has changed something here with Android 15. I'm currently using a Pixel 7 with stock Android 15, open bootloader and root and can't get a positive Play Integrity result (with the modifications) at the moment.
However, these are always just temporary modifications until Google changes something again. If you read XDA on the subject, you'll quickly realise that the modders are almost unable to keep up.
That seems to be the compromise they are prepared to pay.
This is also the reason (besides the slowly malfunctioning hardware) why my wife would like to swap her Pixel 3 LineageOS 22.1 for a device with stock Android out of the box and unlocked bootloader. To be able to use apps again that she currently has to do without.
Modding is becoming increasingly difficult. Everyone has to know that for themselves, but I don't think you should complain if something no longer works as intended.
Of course you can look for solutions to problems and ask for help, but I think sooner or later the point will come when it just won't work any more. It's sad that Android is moving more and more in the direction of Apple, although I can certainly understand the security argument. The users who want far-reaching changes are probably significantly outnumbered in percentage terms.
______
LineageOS ist nicht "Play Zertifiziert". Nie gewesen. Man kann das ( wie von dir beschrieben) auffangen und spoofen wenn man Root versteckt und Module wie "Play integrity fix" mit dem richtigen Fingerprint, "Tricky Store" mir der richtigen Keybox und Module um LSposed und Root zu verstecken nutzt.
Nur mit LineageOS Out of the box ohne Root wirst du das aber wahrscheinlich nie hinbekommen.
LineageOS Ist eben von Natur aus nicht zertifiziert.
Ich habe aber auch das Gefühl, dass Google hier mit Android 15 irgendwas verändert hat. Nutze aktuell ein Pixel 7 mit Stock Android 15, Offenem Bootloader und Root und schaffe es (mit den Modifikationen) derzeit nicht ein positives Play Integrity Ergebnis zu bekommen.
Wie auch immer sind das aber auch jedes Mal nur modifizierungen auf Zeit, bis Google wieder was ändert. Wer auf XDA zu dem Thema querliest sieht sehr schnell, dass die Modder hier fast nicht hinterher kommen.
Das scheint der Kompromiss zu sein, den man bereit ist zu zahlen.
Das ist auch (neben der langsam nicht mehr funktionierenden Hardware) der Grund, warum meine Frau ihr Pixel 3 LineageOS 22.1 gerne gegen ein Gerät mit Stock Android out of the Box und unlocked bootloader tauschen würde. Um eben wieder Apps nutzen zu können auf die sie im Moment verzichten muss.
Modding wird immer schwerer. Das muss jeder für sich selbst wissen, aber ich finde man darf sich auch nicht mehr beschweren wenn was nicht mehr wie vorgesehen funktioniert.
Natürlich darf man Problemlösungen suchen und um Hilfe fragen, aber ich denke früher oder später kommt der Punkt, an dem es einfach nicht mehr funktionieren wird. Traurig, dass Android sich hier immer mehr in Richtung Apple bewegt, wobei ich die Argumentation des Sicherheitsaspektes durchaus auch nachvollziehen kann. Der Nutzer, der tiefgreifende Veränderungen will ist prozentual wahrscheinlich in der deutlichen Unterzahl.
______
Thanks for your reply! I was afraid it would be something like this. I've read things about Lineage not being Play certified, which I found odd since I never had any issues while I've never had to do anything like spoofing. I also got the impression it was me doing something wrong since I had trouble finding people with this issue around the LOS 22.1 upgrade or people in the SHIFT community with this issue. And I agree that it definitely seems like something that has changed since Android 15, since the problems started occurring after the upgrade.
And I didn't mean to sound like I was complaining! I'm incredibly grateful for the modders and their communities for their work with getting these Custom ROMs and stuff to work at all! It's just sad that Google seems to put so much effort in making their lives more difficult. I want to hope things will get better over time, but it just seems that these mindsets of locking down devices and not allowing any customization at all only keep getting worse.
For the time being, I will downgrade back to LOS 21 on my device. If I have more time in the near future, I will look into the options you mentioned or look into FOSS alternatives for the Google Apps I rely on now and maybe ditch the Google services altogether.
I didn't mean to direct this at you personally, but rather as a general appeal. I often see people starting things out of actionism, where they have little prior knowledge, only to realise later that it doesn't work as hoped. This often leads to frustration, which is then vented in forums and discussions. So it wasn't a criticism of you personally, but a general thought. I apologise if the wording was misleading and therefore misunderstood.
Hello BoredStudent,
I had the same problem and was able to solve it after searching on the Internet and in other forums by following these steps:
1. Activate USB debugging and connect the phone to the PC
2. Run the following commands on the PC:
adb root
adb shell
sqlite3 /data/user/$(cmd activity get-current-user)/*/*/gservices.db "select * from main where name = \"android_id\";"
3. The command outputs the GSF ID, which must be registered in your Google account, the URL for this is https://www.google.com/android/uncertified/
4. Give Google 5 to 10 minutes to update their database
5. Deactivate the Google Play Store app and the Play Store services and delete their memory and caches
6. Reactivate the app and the Play Store services
7. It should work now, at least it worked for me
Please excuse my bad English, Google translated this for me :-)
________________
ich hatte das selbe Problem und konnte es aber nach einer Suche im Internet und in anderen Foren durch folgende Schritte lösen:
1. USB Debugging aktivieren und das Telefon mit dem PC verbinden
2. Folgende Befehle auf dem PC ausführen:
adb root
adb shell
3. Durch den Befehl wird die GSF ID ausgegeben, diese muss bei Google in Deinem Account registriert werden, die URL dafür lautet https://www.google.com/android/uncertified/
4. Google 5 bis 10 Minuten Zeit geben deren Datenbank zu updaten
5. Die Google Play Store App und die Play Store Dienste deaktivieren und deren Speicher und Caches löschen
6. Die App und die Play Store Dienste wieder aktivieren
7. Jetzt sollte es funktionieren, bei mir ging es jedenfalls
Bitte verzeiht mein schlechtes Englisch, Google hat dies für mich übersetzt
No worries, I understand. And I fully agree with you there, I wish I could do more myself to help the modding community directly, but I sadly do not have the time or knowledge to get into the development side myself :(
Hello BoredStudent,
adb root
adb shell
3. The command outputs the GSF ID, which must be registered in your Google account, the URL for this is https://www.google.com/android/uncertified/Anhang anzeigen 5711
________________
adb root
adb shell
That sadly didn't work for me... Had to upgrade from LOS 21 back to 22.1 and after that it actually took a few hours before the problem started occurring again. I'll try resetting the Play Store app and the Services again tomorrow, maybe it just needs some more time.
And don't worry about your English. Maybe I should be the one apologizing for speaking English on this forum which seems to be practically German only ;)
I can actually understand a fair bit of German as I am from The Netherlands, but not enough to comfortably write a full forum post... Tut mir leid!
I've waited a bit longer, and today at around 17:00 things randomly started working again! So danke schön to @getle!
Hi @getle,
ich habe versucht gemäß der Anleitung die GSF ID zu ermitteln.
Leider bekomme ich nur die folgende Meldung:
adb shell 'sqlite3 /data/user/$(cmd activity get-current-user)/*/*/gservices.db \
"select * from main where name = \"android_id\";"'/system/bin/sh: no closing quote
Scheint bei meinem SHIFT6MQ mit neuestem LineageOS nicht zu funktionieren.
Freue mich sehr über jegliche Unterstützung.
Freundliche Grüße
Alex
Hallo @alex,
ich bekomme den gleichen Fehler wenn ich den geposteten Code eingebe. Ich vermute, dass irgendein Quote oder Escape Zeichen fehlt oder falsch gesetzt ist und das obwohl der Befehl nach sqlite, der gleiche ist wie bei mir. Die Windows und Linux Shell ist da manchmal sehr bockig, gerade wenn es um das Thema mehrstufiges Quoting und Escaping geht, ich bin da auch schon viele Male beim Programmieren von Shell Scripts verzweifelt. Wenn ich den sqlite Befehl hier direkt in der ADB Shell eingebe funktioniert es bei mir ohne Probleme.
1. adb root → Der ADB Server auf dem Handy wird als Root neugestartet, dazu muss allerdings auch das "Root Debugging" in den Entwickleroptionen aktiviert sein, sonst geht es ne.
2. adb shell → Damit gelangst man auf dem PC direkt in die Shell Umgebung des Smartphones, es sollte dann in der Kommandozeile axolotl:/ # am Anfang stehen, wichtig ist das # (für root) und nicht $ (für user) nach axolotl:/ steht.
3. sqlite3 /data/user/$(cmd activity get-current-user)/*/*/gservices.db "select * from main where name = \"android_id\";" hier raus kopieren, einfügen und bestätigen, danach sollte die ID im Format android_id|<Platzhalter ID> erscheinen
4. Die Steps ab Punkt 3 aus meinem ersten Beitrag ausführen.
VG
getle
Ich habe es partout nicht geschafft, die GSF ID über ADB zu ermitteln. Es gab in der ADB Shell immer die Fehlermeldung Error: in prepare, no such table: main. Wenn ich mir die Eigenschaften der gservices.db im FX File Explorer (root) anschaue, ist die bei mir angeblich 0 Bytes groß. Falls die Anzeige korrekt ist, kann in der DB natürlich nichts drin stehen.
Ich war mir deshalb nicht sicher, ob die GSF ID überhaupt korrekt angelegt wurde, als ich das Smartphone inital aufgesetzt habe. MindTheGapps hatte ich auf jeden Fall vor dem ersten Booten von LineageOS installiert, von daher sollte eigentlich auch eine GSF ID erzeugt worden sein.
Wann genau die GSF ID erzeugt wird, weiß ich nicht. Sie ist wohl je Google Account / Gerät - Kombi verschieden. Daher war meine Überlegung, ob sie vielleicht beim Einloggen erzeugt wird.
Nach dem Ausloggen konnte ich mich aber erst wieder erfolgreich einloggen, nachdem ich die Daten von Google Play Store, Google Play-Dienste UND Google Services Framework gelöscht und rebootet hatte. Google Services Framework erscheint in der App-Verwaltung nur, wenn System-Apps anzeigen angeklickt worden ist.
Nachdem ich mich wieder eingelogt hatte, bekam ich wieder die Anzeige, wie sie hier im ersten Post zu sehen ist.
An der Fehlermeldung in der ADB Shell hat das alles aber nichts geändert.
Damit komme ich zum interessanten Teil:
Es gibt einen Weg, die GSF ID über den Find Hub herauszufinden. Voraussetzung ist natürlich, dass man mit seinem Google Account auf dem Smartphone eingeloggt ist und Mein Gerät finden aktiviert ist. Die GSF ID liegt im Find Hub nicht offen rum, aber ich hatte einen Blog Beitrag gefunden, wo der Weg beschrieben ist, wie man dran kommt. Falls es jemand brauchen sollte, kann ich die Seite noch mal raussuchen.
Nachdem ich meine GSF ID registriert hatte, dauerte es ca. eine Stunde, bis es funktionierte. Vorher musste ich wieder die Daten von Google Play Store, Google Play-Dienste und Google Services Framework löschen.
