Micro SDXC card stuck in SHIFT6mq
Pander
22 Februar 2023
19
I have a micro SDXC card stuck in a SHIFT6mq. Is there a special way to get it out?
The card is really stuck. I was wondering of the hole next to it with the metal latch played a role in it. If not, where is that for anyway?
For me, the SD card can be moved minimally on the side. If your SD card can still be moved, it shouldn't stick. Then you get the card out with patience. Villeiche the card with a needle, and then slide the needle tip from top without pressure but with subtle pressure towards the map exit. So it worked for me several times. Translated with Windows Translater (Translatium). Good luck
Sorry, i tried to upload a video but it doesn't work..
But with a needle as @NoG....eFan said you should be able to remove the sd card
  • Love
