For forkgram and fluffychat; I can see the topics in the ntfy app, which runs in the background over days. To test I used curl to push to the topic of fluffychat but no notification is shown.For which App(s) are you trying to use it.
ntfy is set up accordingly?
ntfy - Android
ntfy (pronounced “notify”) is an open-source push notification service that can be used as a UnifiedPush distributor. You can use it with the default server without needing to sign up for an account. Direct download Details License: Apache2 | GPLv2 Server sources...unifiedpush.org
Yes I am using SOS.7.0.L.20250916. The current situation is it sometimes works with fluffychat. I still need to figure out why and how to let it work consistently.Well as it works now with fluffychat it can not be a general problem. Maybe setting things up anew with forkgram also fixes things. Maybe you missed something.
Just for completeness you are using SOS.7.0.L.20250916?
Per doc, when you launch fluffychat, it automatically sets a topic to the unified push app. In my case I can find it in ntfy.Actually I tried it with Fluffychat but I can't even find how to set up unified push. The setting to choose the distributor is not where it is supposed to be. No problems with other Apps.
Well, what it says is that if you scroll down to the bottom, you will see a list of pushers, as I indeed do. There is nothing to set manually there.Here it says there should be something in Settings -> Notifications.
GitHub - krille-chan/fluffychat: The cutest instant messenger in the [matrix]
The cutest instant messenger in the [matrix]. Contribute to krille-chan/fluffychat development by creating an account on GitHub.github.com
