Does SOS-L support passkey
I think there were some issues with a yubico key but in general it should work. Or was that solved?
Reaktionen: ahoyy
I use the Passkey Option with Bitwarden in ShiftOS - L for some differen App's and it works
Or mean you a "physical Key" like YubiKey ?
Reaktionen: ahoyy
Good to know! Apps aside, can you use passkeys in browsers? And yes the question also concerns yubikey etc (my understanding is that they use in the end the same mechanism)
yes the Passkey Option in Bitwarden works also in my Browser. example EBay LogIn or the Shift Forum.
with the YubiKey or any other i don't have experience
Reaktionen: ahoyy
