(SHIFTphone 8) Bootloader unlock / Root / GSI / ROMs / Mods
Ene
21 Oktober 2020
215
Germany / Bavaria
ONLY PROCEED IF YOU KNOW WHAT YOU'RE DOING
DON'T ATTEMPT TO RE-LOCK THE BOOTLOADER WHEN YOU MODIFIED THE BOOT IMAGE (Flashed Magisk)
I'M NOT RESPONSIBLE FOR ANY OF YOUR ACTIONS
Bootloader unlocking Guide​
Preamble​
Unlocking the Bootloader is required for modifying partitions on the device. This is required for gaining root access or flashing a custom recovery/ROM.
THIS PROCESS WILL WIPE ALL YOUR DATA
Prerequisites​
  • a Linux/Mac/Windows PC (this Guide is intended for Windows 11 users)
  • USB Cable
  • SDK Platform Tools
  • USB Driver
  • Fastboot Driver - those install automatically via Windows Update when the device is attached while in Fastboot mode (make sure you have internet connection and enabled "Give me updates for other Microsoft products when I update Windows." in the Windows Update settings.
Guide​
  1. download and extract the SDK Platform Tools into a folder on your drive root (e.g. C:\adb)
  2. download and extract the USB Drivers into a folder, open it and install the drivers via right clicking on the android_winusb.inf -> install
  3. boot up your device
  4. open the settings app
    1. go to About phone
    2. tap on the Build number 7 times
    3. go to System
    4. go to Developer options
    5. enable OEM unlocking and USB debugging
  5. navigate inside the folder you extracted the SDK Platform Tools to and bring up the cmd (click inside the navigation bar, type cmd and hit enter)
  6. type adb devices and hit enter
  7. on the device, confirm the dialog with "Allow"
  8. type adb reboot bootloader and hit enter
  9. after the devices has entered the bootloader, type fastboot devicesand hit enter
    • if the device shows up continue
    • if the device doesn't show up, open the Device Manager (devmgmt.msc) and look for an not correctly recognized Device (typically labeled "Android")
      • right click "Android" -> Update Driver Software... -> Browse my computer for driver software -> Let me pick from a list of device drivers on my computer -> Show all Devices -> Have Disk... -> Browse... -> choose the downloaded android_winusb.inf -> Android Bootloader Interface
        (guide with pictures)
  10. type fastboot flashing unlock and hit enter
  11. on your device, select the "UNLOCK THE BOOTLOADER" option with the volume buttons and confirm with the power button
  12. reboot your device to the bootloader again (press and hold the power and volume up button or use adb)
  13. repeat the unlocking process but type fastboot flashing unlock_critical this time
  14. your device should reboot and the bootloader is unlocked
Fingerprint Sensor fix (no longer needed with ABL Version ≥ 6.7.0)​
After unlocking the bootloader, the Fingerprint Sensor will stop working.
It's easy to get it working again, if you are still on the SOS-G ROM, because it includes the gf_display_test App. If you are already on a custom ROM, you will have to install the gf_display_test.apk to /system/priv-app (with Magisk).
When the App is installed, make sure USB Debugging is enabled on the device, start a cmd Window in the directory of adb and execute
adb shell am start -n com.goodix.fingerprint.setting/com.goodix.fingerprint.setting.SPMT1Activity
  1. the goodix Fingerprint Sensor calibration App will start
  2. lay a cork (something flat with a skin-like color) on the sensor and press next
  3. lay something flat and completely black on the sensor and press next
  4. now you have to very quickly press next and the put a finger on the sensor
  5. the calibration will say it failed
  6. reboot the device
  7. the sensor should work again
Rooting Guide​
Preamble​
Rooting is the method of gaining the opportunity to modify partitions (from within the userspace).
Requires an unlocked bootloader, follow "Bootloader unlocking Guide"
Prerequisites​
  • The same as for the "Bootloader unlocking Guide"
  • Magisk - download it and copy it onto your device
  • a Magisk-Patched boot.img
    • Patch it yourself using Magisk
      1. download the matching FASTBOOT.tar.gz file for your OS version
      2. extract the boot.img from the FASTBOOT.tar.gz archive
      3. install the Magisk-v*.apk on your device
      4. Start Magisk
      5. Tap on "install"
      6. choose "Select and Patch a File" and select your extracted boot.img
      7. Wait for patching to finish, grab the patched boot.img and proceed with the Rooting Guide
Guide​
  1. install the Magisk-v*.apk on your device
  2. boot into the bootloader (adb reboot bootloader)
  3. navigate inside the folder you extracted the SDK Platform Tools to, copy the Magisk-Patched boot.img into it and name it to magisk_boot.img
  4. bring up the cmd inside this folder (click inside the navigation bar, type cmd and hit enter) type fastboot flash boot magisk_boot.imgand hit enter
    1. if the process is stuck and won't display SUCCESS after about 30 Seconds, abort it in the cmd by pressing Ctrl + C and press the volume-down button on the device to select "Reboot Bootloader". Confirm buy a press on the power-button and try again.
    2. after it displayed SUCCESS you can type in fastboot reboot and hit enter
  5. your device should reboot is now rooted
GSI (Generic System Image) Flashing Guide [UNTESTED]​
Preamble​
A GSI (Generic System Image) is an universal ROM which can run on every Treble enabled device. More Info
Prerequisites​
  • The most recent Version of a LineageOS based ROM ZIP
  • payload-dumper-go
  • product_gsi.img
  • a GSI Image
    • Type arm64_b
    • extracted and renamed to system.img
    • no version newer than the newest flashed LineageOS based ROM because else some sensors won't work
Guide​
  1. Install the LineageOS based ROM following this Guide
  2. Extract the payload.bin from the LineageOS based ROM ZIP
  3. Copy the payload.bin next to the payload-dumper-go.exe and execute payload-dumper-go.exe payload.bin
  4. Copy the following extracted files into a folder:
    • boot.img
    • dtbo.img
    • recovery.img
    • vbmeta.img
    • vbmeta_system.img
    • vbmeta_vendor.img
  5. Copy the product_gsi.img and GSI system.img you want to flash into the folder as well
  6. Copy the following Code into a flash.bat (change fastboot to the path of your fastboot.exe installation)
    fastboot flash boot_a boot.img
    fastboot flash boot_b boot.img
    fastboot flash dtbo_a dtbo.img
    fastboot flash dtbo_b dtbo.img
    fastboot --disable-verity --disable-verification flash vbmeta_a vbmeta.img
    fastboot --disable-verity --disable-verification flash vbmeta_b vbmeta.img
    fastboot --disable-verity --disable-verification flash vbmeta_system_a vbmeta_system.img
    fastboot --disable-verity --disable-verification flash vbmeta_system_b vbmeta_system.img
    fastboot --disable-verity --disable-verification flash vbmeta_vendor_a vbmeta_vendor.img
    fastboot --disable-verity --disable-verification flash vbmeta_vendor_b vbmeta_vendor.img
    fastboot flash recovery recovery.img
    fastboot reboot fastboot
    fastboot flash product_a product_gsi.img
    fastboot flash product_b product_gsi.img
    fastboot flash --disable-verification system_a system.img
    fastboot flash --disable-verification system_b system.img
    REM fastboot flash recovery_a twrp_shift6mq.img
    REM fastboot flash recovery_b twrp_shift6mq.img
    fastboot format:ext4 metadata
    fastboot format:f2fs userdata
    fastboot --set-active=a
    fastboot reboot
    pause
  7. boot into the bootloader (by using Advanced restart / holding down the volume-lower button and power-button together)
  8. execute the flash.bat ⚠️ THIS WILL EARSE ALL YOUR DATA ⚠️
GSIs​
Custom ROMs​
Mods​
  • gf_display_test.apk
    gf_display_test.apk
  1. lay a cork (something flat with a skin-like color) on the sensor and press next
  2. lay something flat and completely black on the sensor and press next
  3. now you have to very quickly press next and the put a finger on the sensor
  4. the calibration will say it failed
  5. reboot the device
  6. the sensor should work again
Das ist neu. Nach den Fehlschlägen habe ich es nie mit nem Neustart probiert.
Das ist auf jeden Fall frustrationsfrei und sehr budgetorientiert.
Super Anleitung 👍🏻.
____
That's new. After the failures, I never tried restarting.
It's definitely frustration-free and very budget-friendly.
Great instructions 👍🏻.
Reaktionen: Martin S. und Ene
Besten Dank für die Anleitung.
Fingerprint Sensor fix​
Allerdings hatte das bei mir mit gerootetem iodeOS 6.11 und 7.2 nicht funktioniert, auch nicht mit als Systemanwendung installierter gf_display_test-App. Weder mit dem adb-Aufruf noch mit Aufruf der Activity über AppManager.
Hattest du gf_display_test nur als System App (/system/app) oder als Priv System app (/system/priv-app) installiert?
Mit welchem intent Befehlt du die App öffnest sollte egal sein, du kannst aber auch noch versuchen über AppManager die andere Activity zu starten (weiß nicht mehr genau wie die heißt) und überprüfen ob "continuos automatic calibration" (oder so ähnlich) aktiviert ist.
Ich habe die Kalibrierung mit einem Kork Untersetzer und einem schwarzen Pop Socket vorgenommen, allerdings auch bestimmt so 15 mal probiert. Ich kann mir vorstellen, dass das auch einen Einfluss haben kann.
Ich habe sie unter /system/priv-app installiert.
Und mit AppManager hatte ich schon alle Activities ausprobiert. Die meisten werden sofort abgebrochen, und die übrigen erkennen offenbar die Hardware nicht.
Aber der Bootloader ist auch noch "unlocked", das könnte auch ein Teil des Problems sein.
  1. Der Bootloader muss für Root unlocked sein.
  2. Das Kallibrieren dürfte wohl nichts helfen, weil bei iodéOS der Fingerprint-Support ja komplett aus dem Build entfernt wurde (bei den anderen OS funktioniert er ja mit locked bootloader).
  3. iodéOS scheint größere Probleme mit dem Fingerprint zu haben als die allgemeinen. Bei CalyxOS mit loked Bootloader (yellow state) funktioniert der Fingerprint nämlich, bei iodéOS mit looked Bootloader (yellow state) dagegen nicht.
Danke für die Zusammenfassung.
2.+3. sind plausibel. Bei 1. ist mir nicht ganz klar, worauf Du Dich beziehst. Nur auf den FP-Reader?
Ich habe meins mit fastboot unlocked (ohne critical_unlock, soweit ich mich erinnern kann), dann iodeOS geflasht und dann das Boot-Image mit Magisk behandelt. Bis auf den FP läuft alles.
Reagiert der UDFPS denn überhaupt auf den Finger? Bei mir hatte er nach dem BL unlock zwar reagiert, allerdings nicht funktioniert.
@Ene das gleiche bei Calyx mit unlocked Bootloader: der Fingerprintbereich leuchtet auf, aber kann nicht eingerichtet werden also offenbar nicht lesen ("reagiert, allerdings nicht funktioniert")
Nein, unter iodeOS gar nicht. Alle startbaren Activities enthalten auch nur leere Textfelder, wo sonst irgendwelche Parameter stehen müssten.
Was (zumindest bei iodeOS) auch noch erschwerend hinzukommt ist, dass der Aurora Store keine Apps mehr installieren oder aktualisieren kann. Auch, wenn man den Vortäuschmodus für ein anderes Gerät auswählt. Das war bspw. auf dem FP4 immer möglich.
Ich frage mich, wie es sich verhalten würde, wenn man ein ShiftOS-L rooten würde. Hätte man dann die gleichen Probleme?
Mit root hat das nichts zu tun. Bei mir funktioniert der UDFPS und Aurora store ohne Probleme, trotz root und offenem bootloader (banking Apps gehen auch). Ich nutze crDroid (was SOS-L ähnelt, beide mit LineageOS verwandt) und Magisk für root.
Kann das nicht vielleicht einfach die "Macke" sein ,die der Aurora Store ab und an hat?
Das kommt auch bei ShiftOS - L (ohne root) manchmal vor und da hilft es oft sich beim Store abzumelden ,die App zu schließen / wieder öffnen und neu anmelden.
Manchmal ist es aber auch nötig den Speicherinhalt und Cache der App zu leeren ,bevor es wieder geht.
Jawohl, das war es. Danke. In der Form kannte ich das von sämtlichen anderen LOS-Geräten noch nicht.
Ich weiss zwar nicht ,in wie weit das zusammenhängt ,aber seit ich z.B. die Installationsmethode im Aurora Store (und in MicroG) auf den MicroG Installer umgestellt habe ,hat sich die "Macke" des Stores (bei mir) bisher nicht mehr gezeigt.
Davor kam es immer wieder mal vor
(Is aber vielleicht auch nur Zufall.😉)
Ich habe versucht den Fingerabdruck Scanner für ShiftOS L nutzbar zu machen. Ich bekam die App installiert und habe Kork und ein schwarze case zu kalibrieren genommen. "continuos automatic calibration" sehe ich nicht einmal ich habe start next darunter calibration und performance. Es läuft in jedem Fall nicht.Hab zwei unterschiedliche Wege angewandt die app ins priv-app zu verschieben. Die Shiftos Versionen waren die vom 22 Februar und das update vom 28 glaube ich.
Kurze Fragen meinerseits an die die ein gerootestes Gerät nutzen (da ich gerne Termux mit sudo nutzen würde):
Kann man bei gerootetem Gerät noch alle Banking Apps nutzen?
OTA Updates gehen dann noch bei OS-L oder nicht mehr?
Kommt auf die Banking Apps an. Also bei Sparkasse / VWBank genügt es root zu verstecken. Das geht einfach mit Magisk indem man dort in den Einstellung die Verweigerungsliste konfiguriert und erzwingt.
Sollte die App aber noch PlayIntegrity voraus setzen wird mindestens noch PlayIntegrityFix und ggf. auch TrickyStore (sofern keine Happy installiert sind) benötigt. Evtl auch noch Bootloader Spoofer und HideMyApplist.
Jede App hat ihre eigenen root-Erkennungsmechanismen. Ich habe meine Verweigerungsliste angegangen, zumindest für all diese Apps ist root Verstecken kein Problem (trotz offenem Bootloader + root + Vector).
Und ja, OTA Updates funktionieren nur noch manuell (das liegt aber am entsperrten Bootloader, nicht am root)
Reaktionen: nau
Nope. Ein unbearbeitetes entsperrtes Gerät kannst du prima per OTA updaten (z.B. bei Nutzung des iodéGSI habe ich das ein halbes Jahr gemacht). Das Problem mit Root ist, dass dir die OTA jedes Mal das Root wieder kaputt schießt, weil es kein Root enthalten hat.
Danke für die Antworten, da werde ich das erstmal verschieben und mir vielleicht in einem Jahr ein Zweitgerät holen um das alles zum laufen zu bekommen bevor ich meinen daily driver zerschieße. Vielleicht wirds dann auch gleich PostmarketOS.
Okay, ich habe nie OS-L genutzt und mich darauf bezogen wie es bei anderen Herstellern ist.
Doofe Frage, aber wo bekomme ich denn ein "a gsi image" her? Es ist ja offensichtlich nicht product-gsi image enthalten:
"Copy the product_gsi.img and GSI system.img you want to flash into the folder as well"
Ich kann nicht eines finden.
Ja das hier wäre das erste mal dass, ich was mit gsi mache da ich es bisher mit allen mitteln erfolgreich vermieden habe. Nur kein bootloader unlock oder kein fingerprint wäre so ein dealbreaker für mich, dass ich das phone zurückschicken würde.
Für ein Beispeil sagen wir das ich Calyxos installieren möchte. Ich denke ja das es mein bisheriger fehler war das ich das gsi als etwas optionales angesehen habe.
GSIs gibts hier und die product-gsi ist nur eine leeres dummy image, das ich hier hochgeladen hatte.
"Kein bootlaoder unlock" verstehe ich nicht, du musst den ja für die Nutzung von GSIs definitiv entsperren und "kein figerprint" hängt von einigen Faktoren ab, sollte aber wahrscheinlich mit GSIs funktionieren.
GSIs sind Generic System Images und haben nichts mit klassischen custom ROMs zu tun (so gibt es auch keine GSI variante von Calyx sondern hauptsächlich nur von LOS basierenden ROMs)
Als Hinweis: Aufgrund der aktuellen Fingerprintthematik braucht man eine neue Kalibrierung für GSIs. Ich persönlich würde für den Anfang lieber CalyxOS, ShiftOS-l oder /e/OS nehmen, weil da mit Bootloader-Lock der Fingerprint funktioniert.
Danke für die schnelle Antwort. Bootloader unlock und ein funktionierender Fingerabdruckscanner sind für mich teil dessen was ich als minimum für min Handy ansehen.
Heißt das die Calyos installation sollte auch ohne gsi funktionieren das ist nämlich mein nächstes problem. Ich kann Shiftos L, I, E/OS und Iode OS mit dem selben Kabel/port und der selben Fastboot installation, installieren aber mit Calyxos endet es immer in einem trotz nochmaligen factory reset Bootloop. Der Fingerabdruckscanner wird dann wohl mit dem gsi nach der installation von calyxos möglich gemacht?
Also geht der Fingerabdruck nur mit einem GSI. Ohne Shift OS gsi brauche ich eine Lineage os basierende rom.
Aua. Aber das tut mir wirklich in den Augen weh. Hast du meine letzte Nachricht (und die von ene) wirklich gelesen und wenn ja, wie viele Gehirnverrenkungen muss man denn anlegen, damit man das so diametral falsch versteht?!?
Ein (Android-)GSI und ein (Android-)OS sind zwei vollkommen diametral unterschiedliche Dinge/Konzepte. Entweder klatschst du auf jedwedes Gerät, dass mindestens vom OEM Android Oreo erhalten hat, ein Generic System Image (GSI) (wie z. B. das /⁠e⁠/⁠GSI oder das iodéGSI), musst aber mit den Einschränkungen (kein Bootloader-Lock (womöglich mit Verrenkungen möglich)) oder du nutzt ein auf dein Gerät angepasstes AndroidOS wie z. B. ShiftOS-G, LineageOS, ShiftOS-l, crDroid, /⁠e⁠/⁠OS, CalyxOS, iodéOS, AXP OS Slim oder AXP OS Pro, kannst das aber nicht auf jedwedes Gerät installieren. Das ist übrigens unabhängig davon, ob Bootloader-Lock möglich ist.
