[UPDATED] (SHIFTphone 8) crDroid 12.9 Unofficial (Android 16QPR2)
Ene
21 Oktober 2020
184
Germany / Bavaria
crDroid 12.9 (Unofficial)​
General
I compiled crDroid for the SHIFTphone 8!
Prerequisites
  • unlocked bootloader
Download
OTA ZIP: https://drive.google.com/file/d/1y0gwSSORGadyGVrVlH-ciIl1rzLSoGU-/view?usp=sharing
Fastboot Variant: https://drive.google.com/file/d/1dQERtm_QScwk7_2EoUhs5ANk9sSKYk_z/view?usp=sharing (Version 12.7, only for first install)
Install
For the first installation, download the Fastboot Variant, extract it and run the commands in the _flash.bat file while the device is attached in bootloader mode.
Update
Just flash the OTA ZIP and wipe cache (reboot into recovery again after each flash)
Source
Building
To compile it yourself you just have to follow these simple steps (and need a beefy PC)
  1. install Ubuntu (you can use Windows On Linux 2)
  2. execute the following commands
    1. install programs
      sudo apt install repo bc bison build-essential ccache curl flex g++-multilib gcc-multilib git git-lfs gnupg gperf imagemagick lib32ncurses-dev lib32readline-dev lib32z1-dev liblz4-tool libncurses6 libncurses-dev libsdl1.2-dev libssl-dev libwxgtk3.2-dev libxml2 libxml2-utils lzop pngcrush rsync schedtool squashfs-tools xsltproc zip zlib1g-dev -y
    2. configure git
      git config --global user.email "you@example.com"
      git config --global user.name "Your Name"
      git lfs install
      git config --global trailer.changeid.key "Change-Id"
    3. configure ccache
      rm ~/.cache/ccache
      mkdir -p ~/.cache/ccache/tmp
      echo export USE_CCACHE=1 >> ~/.bashrc
      echo export CCACHE_EXEC=/usr/bin/ccache >> ~/.bashrc
      echo export CPU_SSE42=false >> ~/.bashrc
      ccache -M 50G
    4. configure working directory (note that mine residents in the folder /home/android/shift8, change accordingly)
      mkdir -p /home/android/shift8/crdroid
      cd /home/android/shift8/crdroid
      repo init -u https://github.com/crdroidandroid/android.git -b 16.0 --git-lfs --no-clone-bundle
      mkdir -p /home/android/shift8/crdroid/.repo/local_manifests
      cat <<EOF >>/home/android/shift8/crdroid/.repo/local_manifests/otter.xml
      <?xml version="1.0" encoding="UTF-8"?>
      <manifest>
        <project path="device/shift/otter" remote="github" name="LineageOS/android_device_shift_otter" revision="lineage-23.2" />
        <project path="kernel/shift/qcm6490" remote="github" name="LineageOS/android_kernel_shift_qcm6490" revision="lineage-23.2" />
        <project path="vendor/shift/otter" remote="github" name="TheMuppets/proprietary_vendor_shift_otter" revision="lineage-23.2" />
      </manifest>
      EOF
      repo sync  --current-branch -j8 --force-sync --force-checkout --force-remove-dirty --prune --auto-gc
    5. optional - increase SWAP size (to 80GB) to prevent out of memory crashes
      sudo -s
      swapoff -a
      rm /swapfile
      fallocate -l 80G /swapfile
      chmod 600 /swapfile
      mkswap /swapfile
      swapon /swapfile
  3. build! (and fix the incorrect ARCH_VARIANT before it)
    git -C ./device/shift/otter reset --hard HEAD
    git -C ./device/shift/otter clean -d --force
    sed -i 's/TARGET_2ND_ARCH_VARIANT := armv8-a/TARGET_2ND_ARCH_VARIANT := armv8-2a/' "./device/shift/otter/BoardConfig.mk"
    source build/envsetup.sh
    brunch otter
This will take about an hour and about 350GB of Disk space [tested with 28 cores and 120GB Memory (40GB RAM + 80GB SWAP]. The build process sometimes crashes because it runs of memory (exit code 137), increase the SWAP size and run the brunch command again. The flashable ZIP can be found in /out/target/product/otter
Erstmal : RESPEKT @Ene 👍
Prerequisites
Versteh ich das richtig - der Bootloader muss "dauerhaft" entsperrt bleiben ,also auch nach vollendeter Installation?!
Demnach würde dann (also wahrscheinlich) auch der Fingerabdrucksensor nicht funktionieren - oder?
Reaktionen: Ene
Ohne custom AVB keys zum importieren würde das Gerät mit einem geschlossen bootloader nicht mehr starten. Da ich nicht plane meinen bootloader zu schließen, habe ich mich damit nicht näher auseinander gesetzt.
Trotz offenem bootloader funktioniert der Fingerabdruck scanner ohne Probleme, eine Anleitung dazu folgt in Kürze.
Hallo, ich habe es zwar versucht, aber ich bekomme den Fingerabdrucksensor nicht zum Laufen. Wie hast du das Problem gelöst?
Dazu gibts nen eigenen Thread:
Ich weiß, das habe ich schon versucht, aber wenn ich „adb shell am start -n com.goodix.fingerprint.setting/com.goodix.fingerprint.setting.SPMT1Activity“ eingebe, blinkt die App kurz auf dem Bildschirm und funktioniert dann nicht. Ich habe nachgesehen und sie in /system/priv-app abgelegt, und sie ist unter „Apps“ sichtbar. Ich habe den ActivityManager verwendet und MainActivity gestartet, aber alles in dieser App ist leer.
Ich hab die App nur unter Shift OS-G aufgerufen, daher weiß ich leider nicht wie sie sich unter einer Custom ROM (vor allem Version neuer als Android 15) verhält.
Hast du es mal mit
adb shell am start -n com.goodix.fingerprint.setting/com.goodix.fingerprint.setting.MainActivity
probiert?
Das startet die Hauptübersicht.
So bin ich unter ShiftOS-L rein nachdem ich in den Priv-Ordner geschoben hatte um zu kalibrieren.
Wie auch LineageOS, /⁠e⁠/⁠OS, CalyxOS, iodéOS, AXP OS Pro und AXP OS Slim. Nur nicht offiziell gebaut, sondern inoffiziell von unserem lieben Forumsmitglied ene, das zu viel Zeit und zu gute Hardware zu Hause rumstehen hat 😉🙃 (nicht ganz ernst nehmen).
Ich war auf der Website. Da werden oder wurden echt viele Geräte unterstützt
Ich nutze crDroid zum Testen auf meinem alten Galaxy S10, läuft schön und es besitzt die eine oder andere tolle Funktion.
Mein Favorit wären die Funktionen und Spielereien von crDroid in der G-Version vom ShiftOS .
Weil das degoogled ist. Er möchte aber Google und die volle Integrität haben.
Einfach Gapps flashen? Den bootloader könnte man auch schließen wenn ein dm-verity Schlüssel in vbmeta geflasht wird (hab mich damit aber noch nicht näher beschäftigt, basic integrity erreicht man aber auch mit offenem Bootloader iirc)
Aber auch mit geflashten GApps hat man nicht die volle Integrität. Vor allem nicht die neue (Name vergessen).
PlayIntegrity mit Hardware attestation? Die kann man mit PlayIntegrityFix + TrickyStore spoofen, was mit installieren Gapps aber gar nicht nötig sein sollte (solange der bootloader wieder geschlossen wird). Zumindest unterstützt crDroid das spoofen nativ (dann kann man aber such gleich microG nutzen).
Hallo Ene,
die Bootloader Version hat sich auf V6.3 geändert. Die Fastboot Variante müsste dann beim nächstenmal auch aktualisiert werden.
Vielen Dank für Deine Arbeit. (y)
