So been reading here and there, and really I don't understand myself so much on all this nonsense. Give me a battery charger any day and what do I need fast charging for? Well, at least less important. Like if you are hiking on hostels, it is much better to have a Battery laying around charging, then a expensive mobile for charging. And at home, it is just easier to flip the battery out and in with a new. Takes like 5-10 seconds on a LG V20, they really made a nice system for the back cover I must say, latest for 4-5 years and still going strong. Although had to clean it out once to make it work again, and had some minor bigger unofficial batteries that needed to modify things a little. But overall, it has worked very very nicely.
The Shift 6mq has a plastic cover, I'm not sure it will be as smooth for exchanging battery as my old LG V20 but looking forward to trying it out. Really if the Shift needs some ideas for a back cover for a future phone the LG V20 back cover might be a thing to take a look at. But with that said, I still have not tried there system out yet, as I don't have the mobile yet. But that should not be long. Sadly not much English Material and maybe I can help a little on that and give it some spotlight
Also I wanna have a Law that makes it illegal to sell phones if it is not possible for the user to change battery and other digital equipment. In any case, lets get to the topic. So I've been reading here and there about chargers. Apparently they suggest a minimum charger with 2 Amps, I have 3 Chargers that does 1.8 Amps QC something form LG, also I have one from Huawei quick charge 2A, which was the one that burned off my quick Charging ability in my LG V20, it got seriously hot using the charger and apparently broke something in it. But my 2 outside Battery chargers saved me on that account but apparently one have to be careful of chargers. I read something that if the Mobile don't uses it all, it will become heat in replacement - although not sure how it overall works.
Anyway, so the Shift 6mq suppports QC4 and PD3 or something of that nature. So I've been looking around, and these are the options I seem to be able to find of likely good options, Shiftphones seemed to suggest Anker as well.
First Anker:
Second Anker: https://mackabler.dk/anker-2-port-u...RN2diBOZM6OM1fe8Vk-mWqXnKoqRL5FQaApZLEALw_wcB
Third hoco, although don't know where to order it in Europe, but it supports QC3: https://hocotech.com/news/hoco-c12q-smart-wall-charger/
These are the 3 options I found, there was a nice travel charger product from Anker but only with the US Plug.... Found it: https://www.anker.com/products/variant/anker-45w-ultraslim-fast-charger/A2617111
Sadly this charger seems to only be for the US plug, no idea why they would not make it with the EU plug but I think it was based on the same Technology as the Anker Ultra Compact model, just in a flat form for travel and easy page and protection of the plug itself. Would have been nice, but apparently I can't seem to find a EU plug.
That's all, come with your own ideas and thoughts, maybe you guys have already tested some
I'm thinking of justgetting the Anker ultra compact and then try my other older chargers out and see how it goes when I get my Shift freedom mobile!
If you write German, no problem - I can translate it
Dearly Regards
- Darkijah
A final note, if there are some issues with the text, I blame Google who seemingly seems to do auto edit while writing!
First Anker:
Anker Ultra Compact 30 W USB C Power Delivery vægoplader - Apple (DK)
Søgeresultater for Apple Store
www.apple.com
Dearly Regards
- Darkijah
