adb backup -all but I think I can only restore it if the bootloader is locked again(? or its doesnt work at all, its a very old method 2011), also I dont want my phone to show a "warning" after every restart)So if I lock the bootloader again the devices is not longer rooted, correct?Both unlockingfastboot flashing unlockand lockingfastboot flashing lockrequires a factory reset!
I am not completely sure but I think creating and restoring a backup has nothing to do with the bootloader state.
So how exactly do I lock the bootloader again?It is still rooted!
fastboot flashing lock but that does not work(I now hang inside of the bootloader)? Do I need a command to make a factory reset?I did the same steps as for unlocking the bootloader, but if I select "START" in the bootloader I am in a loop that brings me strait back to the bootloader.Booting into the bootloader and executing above command normally should do the trick.
OEM unlocking is still enabled in the developer settings?
In general if you successfully rooted the phone and kept the settings locking the bootloader again should work. Or in other words following the same steps as for unlocking should work.
Yes it was I couldnt disable it anyways, I think it was greyed out but enabled.OEM unlocking is still enabled in the developer settings?
adb reboot bootloader?What do you mean by "START" in the bootloader? The point from the instructions when you reboot into the bootloader?
Nope doesn't work "error: no devices/emulators found" but if I lock/unlock the bootmanager it updates the above view.Does it work if you reboot from the command line usingadb reboot bootloader?
adb devices give you?I just want to boot into Android after changing the bootloader option.I am more and more confused!
I don't know why you want start or stop. The guide says nothing about it.
Yes I can switch it to locked or unlockd as often as I want.If you are there you should be able to lock or unlock the bootloader.
Yes, I cant boot.Are you saying the device is not able to boot normal?
Yes as meantioned before I can change switch it.Also it says "Device state - locked". So the bootloader already seems to be locked.
Also are you really sure you can access the device using adb?
Currently adb devices does indeed not list any device but earlier it was able to list my phone.I don't think so given that it does not find devices or emulators? What doesadb devicesgive you?
Did you flash a bootimage matching for your OS Version? Maybe, also wipe Data in Recovery Mode and try again.I just want to boot into Android after changing the bootloader option.
Yes, I cant boot.
And even though it currently does not list any device I can still shuffle between locked and unlocked. :/
It is probably really a corrupted image or so...
Nope doesn't boot no matter what I do.Strange!
And it also does not boot if you are in unlocked state?
How would I do that?If the boot image really is corrupt maybe flashing it again could help!?
Yes I think so I had 3.3-L and flashed the magisk_boot_shift6mq-sos-3-3-l-20210709.imgDid you flash a bootimage matching for your OS Version?
How would I do that? If I select recovery mode my phone restarts but the screen afterwards seems to be the same as the one before.Maybe, also wipe Data in Recovery Mode and try again.
Well, I think you rooted your phone? During that you had to flash the magisk patched boot image, didn't you?How would I do that?
When dealing with such things it is very dangerous to just think or believe. You ought to know!Yes I think so I had 3.3-L and flashed the magisk_boot_shift6mq-sos-3-3-l-20210709.img
Ah, I didnt noticed that there where 3 different 3.3 versions. My fault.Well, I think you rooted your phone? During that you had to flash the magisk patched boot image, didn't you?
Up to now there are three versions of ShiftOS-L 3.3:
SHIFT6MQ.SOS.3.3.L.20210519
SHIFT6MQ.SOS.3.3.L.20210624
SHIFT6MQ.SOS.3.3.L.20210709
So if the versions did not match this might be the reason for your problems! Using the correct image might fix your problem.
Then probably you do have not the latest version (20210709). So you can try if flashing one of the two older versions of the boot image fixes the issue. The one matching the version you have installed should fix it. In this thread you will also find the older versions provided by @@Lhotze.Ah, I didnt noticed that there where 3 different 3.3 versions. My fault.
So how can I flash my phone again?
fastboot flash boot YOURIMAGEI tried all three "Boot-Magisk-SHIFT6MQ.SOS.3.3.L...." versions after sucessfully unlocking the bootloader again: "fastboot: error: cannot get boot partition size"Then probably you do have not the latest version (20210709). So you can try if flashing one of the two older versions of the boot image fixes the issue. The one matching the version you have installed should fix it. In this thread you will also find the older versions provided by @@Lhotze.
You said you can lock and unlock the bootloader. Then you first need to unlock it again and flash the magisk image as described in the guide usingfastboot flash boot YOURIMAGE
Es gibt schon eine viel neuere Stable Version, vielleicht mal updaten?
Hier sind boot.img und recovery.img - https://downloads.shiftphones.com/public/SHIFT6mq/release-light/SHIFT6MQ.SOS.3.1.L.20210226/IMAGES/
Sollte gehen
adb devices I can see it using fastboot devicesIt is hard to say what is going wrong here!I tried all three "Boot-Magisk-SHIFT6MQ.SOS.3.3.L...." versions after sucessfully unlocking the bootloader again: "fastboot: error: cannot get boot partition size"
I don't think this will work, these are even older versions and it has to fit the version you have installed.Can/should I try some of the other images? Or which one should I try to boot to recover my phone?
Yes the have.It is hard to say what is going wrong here!
The magsik patched boot images have the correct size? 20210519 (13107200 Bytes), 20210624 (13185024 Bytes), 20210709 (13189120 Bytes)
Maybe I still use the version from March instead of the April one:You are using the latest platform SDK?
I thought I checked for the newest version before updating or at least the last time I tried to update isnt too long ago(last few months)Your OS version is not 3.3-something but again some other (maybe older) version?
Maybe it looks like locking and unlocking works but does not!?
You somehow botched the system, e. g. the partition table.
If nobody else has other ideas it is probably best to contact Shift. Sending in the device for repair might be the only option then!
I am already failing at this step, I think I cant enter the recovery mode if I select "Recovery mode" the phone restarts but the screen afterwards is the same as before. From what I searched online I think it should be some kind of additional menu and the first line should state something like "Recovery mode", but this is not the case, I just see the usal Bootloader screen(the one I already posted).I would recommend to unlock Bootloader, boot into recovery, Install latest Beta-Version out of the Recovery with adb sideload.
fastboot flash boot magisk_boot.img so now I can at least boot again
