SHIFT Battery magazine draft
Ronen
6 Januar 2026
4
Claim:
1.Sliding rails fixing the battery magazine
2. snap-fits fixiing the battery magazine
3. bouton releasing battery magazine (like Gun's magazine)
4. Watter proof ring protect connect pole prevent liquid invade
So... How would you deal with stereo Speakers? Where to put the Antennas which may need to be in the lower part of the phone? Where would the Vibration motor be located?
Regarding simplicity, I understand that waterprofing and handling by the user may be simpler, but everything else is more complicated and expensive:
  • Charging hardware in each Battery increases price.
  • Complex locking mechanism increases price.
  • Protective shell in each Battery increases price (the phone still needs a hard outer shell, but now the battery does aswell).
  • Wireless charging hardware in each battery increases price.
  • If anything breaks the battery and surrounding hardware needs to be replaced, which is less sustainable.
  • Higher capacity is a claim, which has to be substantiated. I expect the opposite.
  • New battery system is not back compatible, which increases price and reduces quality for legacy device battery replacements.
  • The supply chain gets more complex due to more components.
The current battery is the minimum viable product, which is the best for a sustainable replacement module.
Thanks for your reply, I have some explains for detal and solutions :
Ans: This draft just only concept of pouch battery module, not final sample, Antennas and Vibration motor.... other module parts able to located at phone fram right side and left side,There will be no Conflict with the battery magazine. I will continue with the circuit design
Ans: No, because its just move Charging hardware from phone to Battery magazine , Not adding second one in Battery Magazine
Ans:
1.Using hard plastic snap-fits won't incur much cost. even if while using small number of metal is possible, they are still significantly cheaper compared to using screws.
2.Due to Recent EU regulations have placed a stronger emphasis on the structural robustness and drop resistance of smartphones,like(EU) 2023/1670 and (EU) 2023/1669,The EU may place greater emphasis on drop resistance in the future. Its may main reson why Fairphone 6 used pouch battery then screws fixed it becomes many users inconvenient.
3.This locking mechanism likes LG G5, its not also increasese price , ref: https://en.wikipedia.org/wiki/LG_G5
4.It might even using for customized 3D printing.
5.Even if at a higher price point, I believe the product's uniqueness and scarcity will attract a group of high-end users willing to pay a premium, especially through a customized production system
Ans:
1.If using battery magazine ,the phone no need (or no need whole)hard outer shell,because Hard battery magazine shell as phone outer shell(phone back cover). One shell protecting battery magazine and phone at the same time.
2.This also helps reduce material waste for the phone's back cover.
Ans: In my design draft picture.1:Wireless Charging and Solar Charging are "Optional" items Its means When purchasing the battery magazine, you can customize the configuration to choose what you want or don't want. if you needed you can buy option item add on,if you not needed you can don't buy option item or remove it.
Not every battery magazine include "Wireless charging or Solar Charging"
Ans:
If anything breaks the battery or battery worn out →just only replace the battery magazine or battery cells. No need replace other surrouding hardware or other module
Ans:
Evidence 1:https://pubs.rsc.org/en/content/articlehtml/2025/eb/d5eb00126a
Evidence 2:https://www.sciencedirect.com/science/article/abs/pii/S0378775323007711 (Elsevier, Journal of Power Sources)
Evidence 3:https://www.sciencedirect.com/science/article/abs/pii/S2590116819300104 (Pouch battery densities)
Evidence 4: largest capacity(8000 mAh) phone now used pouch batterty https://www.androidauthority.com/honor-power-3544757/
As a sustainable brand, we can no longer afford to remain passive in a niche market. We must take the initiative and aggressively compete in the mainstream market. So...Our quality and performance cannot fall too far behind the market average in the Future.
Ans:
1.My project purpose not disuse previous prismatic battery(5me 6m or 8),in my project the new phone replacing "frame module A" able to use previous prismatic battery ,the same way, change to another "frame module B" able to use pouch battery magazine, Not waste anything.
2.My design purpose also "Forward Compatible", in Future only replace or upgrade old module may not necessarily need to replace whole phone,in the Future.
Ans: With SHIFT’s robust recycling system, this transition should be manageable. My vision is a flexible modular system: one module can be shared among multiple users, while one user can also own multiple modules. This How approach benefits the environment while safeguarding the profit margins for both suppliers and SHIFT—addressing the core reason why sustainable brands often struggle to maintain strong relationships with suppliers and ODMs.
.......thereby furthering the ideals of ESG and SDGs
Before I'll get to your answers, I have another question. How do you suggest to maintain full USB 3.1 functionality including external displays, networking, data transfer and much more? Will this need to be routed through the battery module, increasing complexity and cost? Or do you suggest an additional USB-C connector on the phone, which increases complexity as well?
Currently the (replaceable) sub-pcb with the attached (replaceable) usb port is connected with a (replaceable) ribbon cable to the (replaceable) mainboard containing the chipset with the charging hardware. Considering routing the data connection to the battery's usb port, you'd unify four/five individually replaceable modules (battery, sub-pcb, ribbon cable, usb port, charging hardware on mainboard) into one single module. This reduces modularity which makes repairs less sustainable.
To my knowledge, the charging hardware is included in the chipset. This makes it so that it can't be removed without choosing another chipset without charging hardware. I doubt that the latter exists, but even if it does it requires a complete redesign of the phones internals. The other option is to not use the existing charging hardware (making it redundant) and adding a new one in your battery module. To me, this doesn't sound sustainable. Another option is to route the electricity from the port through the battery to the chipset and then back to the battery, in which case the battery wouldn't be able to charge outside the phone. How are you planning to handle this problem created by the modern integration of charging hardware into phone chipsets?
Which increases the frame width and decreases the space for the battery.
Yes. And if you own two batteries or replace a battery you don't only pay for the battery but also for the fast charging hardware. Also as explained above, you can't simply move the charging hardware, since it is an integral part of the phones chipset. So you'd need to double the charging hardware
So a moving mechanism with custom parts is cheaper than mass produced screws?
I can respect that. Although, it'll make the already expensive sustainable SHIFTphone more expensive to the average user, making the entire concept less sustainable.
You are either suggesting, that the phones internals are exposed to the battery magazine slot, or you are neglecting, that the phone still has a back cover behind the battery. This comes down to the question if you see phone internals or the phone shell/cover when the battery is removed.
If you had exposed internals to the outside (battery magazine slot), then yes. But it will increase waste when replacing the battery, which is typically replaced before the phone is EOL. So overall increased waste.
So worse and more expensive than current system? You pay a premium to add another (originally replaceable) module to each battery. With the current system you buy the hardware with the phone, with your system you buy the hardware with each battery you want to own, making it inferior because less sustainable and more expensive.
The pouch cell studies apply to both your and shifts battery. Both are pouch cells surrounded by some hardware and casing. Although you are increasing the hardware and casing in your design. The original battery needs only minimal casing, because it is protected within the phone, your design needs much more robust casing protecting the battery.
This means, you reconfigure the phones internals (if possible) and add a mechanism (rails, buttons, and retaining clips) into the same space, which would leave less space for the battery? Also you create expensive new hardware, replacing about 50% of the phone (frame, sub-pcb, antennas, antenna cables, usb port, speaker, microphone, battery, back cover, wireless charging, nfc coils), which makes the old parts electronic waste?
How many would buy the new system for legacy phones? The RnD for it would be quite expensive and needs funding.
It's also misleading to call one battery prismatic and the other pouch, when both contain a battery pouch in a casing with hardware. What I see in your concept is starting from the same battery system but than adding more casing, more hardware, and a more complex mechanism, requiring relocation of lower antennas, the speaker, the microphone, and the vibration motor.
This already applies to the current battery module.
Does not address my concerns with increased supply chain complexity. Everything you say applies to the current battery as well.
I'm considering, that every user will buy an average of two battery modules. One with the phone and one replacement later on. This means all hardware included in the battery module would be bought twice. The average user also removes the battery a single digit or low double digit amount of times during the phones lifetime. Imho this means, that the battery module should contain as little hardware as possible and the mechanism should be rather resourceful than fancy.
Edit: Parts of your text seem AI-written, which doesn't add credibility to your idea. There are clear indications like changes in writing style, unnecessary abbreviations and overly fancy words, and the famous "–", for which LLMs are known.
No
No need PCB in magazine,only charging IC,and connector
The core principle of my design is to integrate the already finalized external charging case and portable protective case integrate into a detachable plug-in battery magazine, further simplifying both the structure and the operational workflow→
URL: https://www.youtube.com/watch?v=ZLATtfNxqoQ&t=1010s
Battery Magazine include:【battery cell,USB-C port,Power pass-through,data pass-through,Charging IC, BMS/NTC Chip(I considerate),connector/FPC】
Phone PCB include:【PMIC,Charging control,USB Controller,USB PHY,PD negotiation】
External Charging pathway: charger→usbc→charging IC→battery
Interlnal Charging pathway:charger→usbc→PMIC/charging IC→battery
Ans: Other brands Any phone increase battery size also decreases space for other components
1.Any technology progressive will inevitably increase short-term costs,also increase some hardwares,Otherwise, we’d be heading back to the era of the Nokia 3310.
2.Besides allowing users to replace batteries more easily.The battery magazine concept undeniably adds a small amount of extra power management chips and transmission cable components. However, in comparison, it can reduce the excessive production and waste of external chargers, power banks, battery protection cases, phone back covers, and adapters. It can also extend the lifespan of smartphones, thereby contributing to sustainability and environmental protection.
3.the pouch battery inside the battery magazine can provide a larger capacity, it can reduce the need for carrying multiple spare batteries for outdoor workers and travelers, thereby reducing the over production and waste of battery cells. For example, outdoor workers or travelers who previously needed to carry three spare batteries may only need to carry one or two battery magazines in the future.
4.The SHIFT battery magazine is not intended solely to power SHIFT smartphones. If SHIFT establishes a universal standard in the future, the same battery magazine could also be a battery for drones, robots, labtop, AI hardware, surveillance systems, autonomous vehicles, and many other devices. This would create a more sustainable and environmentally friendly ecosystem. Moreover, it can instantly function as a power bank to charge other USB Type-C devices.
5.Extra battery magazines could also be shared or rented among other SHIFT users.
You may refer to the previous LG G5 as an example.
Thanks
Customers who want a buffet-style choice should have the freedom to choose it, rather than being forced by manufacturers to accept a fixed set menu.
Currently, all smartphone brands have taken away customers’ right to choose a buffet.
1.The value of modular products lies in giving customers the freedom to choose carte buffet, rather than forcing them to accept a fixed set menu. Of course, customers must also pay a higher price for the premium options they choose themselves.
2.Just like a buffet restaurant, we should not offer only low- to mid-range dishes. We must also provide high-value premium options and allow customers the freedom to choose.
I suggest we should not limit ourselves to only the low- and mid-end markets while giving up opportunities in the high-end market.
1.I would design the bottom section using a softer and lighter plastic rather than the harder plastic used for the battery magazine, because the rear side of the bottom section sits directly against the display module.
All phone internals, chips, and PCBs would also be enclosed within the phone frame in order to achieve a high level of water resistance.
2.My goal is to make the smartphone usable for as long as possible, ideally without ever needing to be abandoned or replaced.
1.Basically, it depends on customer demand. If customers want features such as wireless charging, solar charging, or other additional functions, they could register through a future pre-order system and pay for customized configurations in advance, helping to reduce unnecessary waste and overproduction. If customers do not need those features, they can simply purchase the standard configuration instead.
2.The vision of future Industry 4.0 or 5.0 is to enable a demand-driven model led by customer needs.I hope so...
My original design concept was this: since smartphones from other brands already use pouch batteries, and their casings whether metal, glass, or hard plastic are already capable of protecting those pouch cells, I can simply repurpose part of the phone’s outer casing into a protective shell for the battery magazine to protect the battery cell itself. The section removed from the phone casing would then be replaced by the battery magazine casing, allowing one structure to serve two purposes.
1.Currently, every smartphone brand develops completely new parts for each new generation. At our SHIFT as well, from SHIFTphone 4.2 to 8.1, every generation has required newly developed components. Even Fairphone is the same :from FP2 to FP6, the parts cannot be reused or made fully compatible with older devices.
This is also one of the main reasons why I designed the “Project of SHIFT LIFE.” I hope that in the future, under my Project of SHIFT LIFE plan, new modules will be able to work with older phones, allowing users to upgrade existing devices instead of replacing the entire phone, thereby reducing electronic waste. →https://forum.shiftphones.com/threads/project-of-shift-life.7951/
2.Rather than being afraid of electronic waste, it would be better to establish a proper modular recycling system.
Last year, I was already thinking about some possible solutions. For example, in the future, if customers want to purchase a new module, they may first need to recycle an old module. After the recycling company or department confirms the returned module, it could send a verification code to SHIFT. SHIFT would then issue a new authorization code to the customer, which would either allow the new hardware module to be activated or grant permission to purchase a new module. At that point, we can decide whether the authorization code should be linked to the online store account or bound directly to the hardware SoC.
1.our 6m 4242 mAh battery unable using in 8.1
2.8.1 battery need "adaptor" to 6m or 6mq (By your logic, adapters could also contribute to electronic waste)
3.Besides the battery, the camera module from the SHIFTphone 8 or 8.1 also cannot be installed on the SHIFT6m
4.Additionally, I would like to ask you: if the physical size of the current SHIFTphone 8 battery remains unchanged in the future, what technologies could be used to increase its capacity to more than 5000mAh?
1.as for other module:I suggest establishing a universal "SHIFT standard" in the future, integrating with third party companies, and moving toward an open source hardware and customizable hardware ecosystem.
2.As for batteries:almost smartphone brands currently use pouch batteries, so obtaining pouch cells or more advanced battery technologies from the supply chain side would be much easier for us.
As I mentioned before, our advantage is giving customers the freedom to choose their own “buffet” configuration.
  1. Customers could freely choose to purchase Frame Module A with the phone and only one battery magazine, without needing to buy additional spare battery magazines.
  2. Customers could also freely choose to purchase Frame Module B, which is compatible with the original Prismatic cell batteries used in devices( such as the SHIFT6m and SHIFTphone 8.1. Battery size)
However, you also need to consider users who work outdoors, users who cannot reliably access charging, or users in emergency situations such as military personnel, police officers, medical staff, and other professionals who may be unable to charge their phones for extended periods of time. For them, fast swappable batteries are extremely important.
For example, a few years ago, our Taiwan experienced a major earthquake disaster. People were trapped, and fortunately the swappable battery design of SHIFT phones allowed us to quickly restore power when our phone batteries were depleted. This enabled our phones to continue functioning, until police and rescue teams to locate us. The SHIFT swappable battery system helped protect and save our lives.
If swaping the battery becomes more difficult, our brand and values will lose attractiveness and uniqueness.
Users who need swappable batteries should also be respected.
I am not AI, but I belive in the future AI can help us solve many of the challenges related to modular smartphones, allowing their quality and functionality to continuously improve over time.For example, issues related to weight, thickness, module compatibility, and many other challenges.
I am very confused by what is happening here. You're using the SHIFT logo but are you a representative of SHIFT or just a normal community member just like us. If you were the former, I would be shocked by how the idea is being represented as I expect more structure for official SHIFT projects.
All I get from reading this thread is eye pain from all the colours. It's hard to understand what exactly is proposed in here, as the initial post only contains some interesting pictures and 4 bullet points. Some more information would help me understand what your idea and project is. Explained in a simple way please :)
I think a different form of presentation could help the project to be accepted more and helps bringin it more forward. In my eyes there is to much glitter, colour and bloom which makes the presentation less serious and more difficult to understand and follow – but this may also be just my taste, other people may or may not see this different ;)
I always love when communities are starting to build their own ideas, giving inspiration for SHIFT itself but also building up an ecosystem which helps convincing more people of the SHIFT-world. So thanks in advance for your effort!
I always loved using them but since LLMs, I unfortunately try to avoid them depending on the context :(
Reaktionen: Rigol
Of course they do. But by keeping old devices alive they may prevent more waste than they create.
Yes. This however is not only a problem of the formfactor. The SoC needs to be fast enough to work in unity with the camera module. So maintaining compatability is not possible. This is why the Google Project Ara failed. It was planned as a fully modular "buffet style" smartphone, but it turned out, that it is not viable. You still need to replace most of the phone when upgrading and the modularity reduces compactnes and IP rating.
The same way they have been increases for the past years without increases in battery size. Battery capacity doubled without phone sizes doubling. As I'm not a researcher on the field of batteries, it's not necessarily up to me to know that.
So, the current battery system already does what you are advertising for the new one?
I never said that. However, I was implying that parts of your text were AI written.
You are presenting lots of bling, with may fancy words and wonderful promises. But I fail to see anything that proves anything. No proof of viability, no proof of increased capacity. Not even any back-of-the-envelope cost calculations or estimations. I see some images and you postulate great advancements. I'm sorry to be harsh, but for me that is not enough. That isn't a concept, it's an idea waiting to be figured out or discarded.
I hope for much more technical detail, until then I remain of the opinion, that this will only add complexity and cost whilst reducing modularity and sustainability. The reasons why have been layed out by me.
